configure cfm segment delete domain association
configure cfm segment segment_name delete domain association
Description
Deletes a CFM domain from a CFM segment.
Syntax Description
segment_name
An alpha numeric string identifying the segment name.
Default
N/A.
Usage Guidelines
Use this command to delete a CFM domain from a CFM segment.
The following command deletes the domain and association from the segment s2.
configure cfm segment s2 delete domain association
This command was first available in ExtremeXOS 12.3.
Platform Availability
